need help .
(Topic created on: 05-07-2022 07:27 PM)
igan
Doe's the galaxy s22 ultra 512gb usa unlocked ( SM-S908UZKFXAA ) work with cdma network's , like : CDMA2000 1xEV-DO  ?
15 Comments
abu1amir
Note that I told the employee if it works with the CDMA system, and he answered me that it works with all systems, that it is open, which made me buy two other devices, and none of the devices worked with the CDMA system in the State of Yemen
abu1amir
Hello, my phone does not work with the CDMA system, knowing that the purchase was made from the store, which is unlocked
VikrantTambade
I had already advised you to check with customer service through get help section of this app.
They will tell you the exact details.
abu1amir
In the phone information, I see the CDMA system, but the system is not activatedScreenshot_20230410_112712_Phone services.jpg
abu1amir
I hope that one of the Samsung employees will believe me in activating the CDMA system and that the device is globally unlocked
abu1amir
