need help .
(Topic created on: 05-07-2022 07:27 PM)
igan
Doe's the galaxy s22 ultra 512gb usa unlocked ( SM-S908UZKFXAA ) work with cdma network's , like : CDMA2000 1xEV-DO  ?
15 Comments
VikrantTambade
If you want to use the device as CDMA then u would have bought it as carrier locked itself in USA.
Unlocked will be compatible with GSM sim cards, as far as I know.
igan
it is unlocked .
VikrantTambade
Better check with customer service through help section of Members app.
igan
i have the s21 ultra usa and it work with cdma , but the s22 ultra usa doe's not work with cdma . Why ?
VikrantTambade
Simple Google search gave me answer as highlighted in screenshot.
The comment is against S22Ultra Unlocked version. Screenshot_20220507-195429_Google_114821_1651942469.jpg
igan
Mine is samsung unlocked ( SM-S908UZKFXAA ) from samsung web site .
igan
is not t-mobile or verzion or att or us celluer , it is samsung unlocked from samsung usa website .
abu1amir
كذبو عليك مثلي قالو مفتوح
لما وصلتو اليمن وفوجئتو ان الجهاز لا يعمل بنظام cdma
Samsung_specialist
Hello,​
Please provide us with more details in order to assist you better.
