Network Issue auto switch 5g to 4g in S24 Ultra after One UI 7 Android 15 update
(Topic created on: 04-24-2025 11:21 PM)
salimkhan666
I have been experiencing a new Issue on my Samsung Galaxy S24 Ultra since updating to One UI 7 (Android 15) last night.
Since the update, my phone frequently switches from 5G to 4G. This has happened more than ten times today. I have tried several troubleshooting steps, including toggling airplane mode multiple times. I also searched online for any solutions and followed suggestions such as disabling power saving mode and ensuring all apps are updated and setting is ok and reseted my network setting but after sometime it switchesto 4g LTE again.
my other phone, with the same network sim card, is working perfectly fine and consistently maintains a 5G connection, the network on my S24 Ultra has switched to 4G again while typing this post.
This issue is significantly impacting my data usage services, I request samsung team assistance in resolving this network instability on my Samsung Galaxy S24 Ultra.
Please let me know what steps I should take to diagnose and fix this problem.
11 Comments
iam_Sara
Yes me too experiencing..🙄
salimkhan666
did anyone notice the slow charging issue
Ronny8984
I got the update but didn't update it. Samsung has given this update because of people's anger on the late update arrival. Now they will fix it and it will take some time
salimkhan666
exactly that's the matter, u r right Bro...
cs_member10
Dear Samsung Member,
As per your concern, you have already done the possible troubleshooting steps and the issue remains unresolved, we request you kindly share the log file. Also, share the video clips and images for better understanding. This will help us to investigate further and resolve this issue.
To share the log file: Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.
goodthings
It's a major update. Kindly reset factory data with backup then try to it's again. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
Your's most welcome to here.
salimkhan666
that's what i had to do everytime 1745611101471.jpg1745611101484.jpg1745611101500.jpg1745611101513.jpg
rkd26
Same with my s23 ,got the update today and since then it's the issue
