Build quality (issue) of S23.
(Topic created on: 08-09-2023 10:11 PM)
kaushikwho
I am not sure if this is a problem that I have been facing or if everyone else has it too.
Whenever I press the back glass just above the SAMSUNG logo, I can hear a creaking sound, almost like when glue peels off.
So anyone with a Galaxy S23 or S23+, can you confirm it for me?
There is also a mark exactly there. Idk how it got there, but it feels like it's under the glass. When I wipe it with a cloth, it disappears. But the reappears when I touch the spot with my bare hands. I think the back glass wasn't frosted perfectly which leaves a mark when touched with hands.
Also, I always use a case. So it's generally not visible, but I'm still concerned about the life of the back glass because of the creaking sound.
6 Comments
TSeries
I think you are right.
Froasted paint on the back of glass got seperated and making creaking noice.
I don't see any other reason why Service center won't replace the glass for you.
Go to SC
kaushikwho
Okay, thanks a lot! Will pay them a visit tomorrow.
ArjunBalhara
Bro supreme court nhi jana , consumer court ja
kaushikwho
AHAHAHAHAHAH haan bhai, bilkul. Kal jaunga XD
cs_member10
Dear Samsung Member,
We acknowledge your query and apologize for the inconvenience caused to you and will surely assist you regarding the same. We request you to kindly visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
kaushikwho
Okay, thank you!
