wifi problem
(Topic created on: 01-15-2017 10:43 PM)
haitham89
wifi turned on automatically. ..I turn it off and after like 5 minutes it turns on by itself. I tried to look up the issue, but i can't find anyone reported it before..plZ any one help me
2 Comments
jove
i was having the same problem few months before....the real culprit is the antivirus installed.... uninstall the same....problem solved😀
SamMobile2
you have an app that uses wifi
