08-13-2021 01:12 PM (Last edited 08-19-2021 08:47 PM ) in
Galaxy S- Just turn off Unused apps to sleep, and remove all the Sleeping and deep sleeping apps from the list.
- Also turn off the Adaptive battery.
08-13-2021 07:38 PM in
Galaxy SHow much time with 25W charger?
And thank you for this tip. Gonna try it now..
08-13-2021 07:50 PM in
Galaxy SAnyhow will measure the charging time and will let you know..
08-13-2021 07:55 PM in
Galaxy SMy SOT on 120Hz is usually around 6hrs with Wi-Fi on and location, Bluetooth, mobile data off.
Let me see if I get any improvement.
BTW can't we disable this device care app using adb? 😅
08-14-2021 08:28 AM in
Galaxy S- Mark as New
08-14-2021 09:34 AM in
08-14-2021 09:50 AM in
08-13-2021 09:14 PM in
08-14-2021 08:29 AM in
08-14-2021 09:39 AM in
Galaxy SHere are the Screenshots of Samsung apps overall battery usage in my use case Scenario...
OneUI Home
Before - 5.4%
After - 3.6%
08-14-2021 09:42 AM in
Galaxy SBefore - 4hrs 2 min caused 1% battery drain
After - 4 hrs 32 min caused 0.6% battery drain
Keyboard Content Center
Before - 8hrs 6min caused 1.2% battery drain
After - 8hrs caused 0.8% battery drain
And there are other apps such as samsung Core Services, Bixby Voice, Hiya Services etc have massive drop in drain...
It did worked for me... (s20 FE 4g)
