Slow charge for s24 ultra with samsung 45W charger
(Topic created on: 12-29-2024 11:04 AM)
ShivaNaveen
Hello Everyone,
I am facing slow charge issue for s24ultra with samsung 45w charger which I ordered from samsung official website only. (1.5 to 2 hours)
Cleaned charging port
Enabled fast charge in the mobile
Using original charger and cable.
Anyone facing similar issue?
Please suggest any solution?
With same charger s22 ultra is charging fast.
Oneui_new
You can charge at 25w with even you have 45w charger because you need a 5A cable for fast charging with 45w samsung charger.
ShivaNaveen
Yes. I am using 5A cable only which comes along with charger
goodthings
Kindly reset all settings of your's device in general management settings also Flight ✈️ mode on n off one time also optimize your's device in device care too then try to it's again. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
ShivaNaveen
Reset the settings also difficult to me. Thanks
goodthings
It's very simple, please go to setting, click general management settings, and click reset all settings. Thanks.
ShivaNaveen
I know the steps but again I need to change the settings, this is my problem
goodthings
Ok, as you like. Thanks.
goodthings
Your's most welcome to here.
cs_member10
Dear Samsung Member,
As per your query, you have already done the possible troubleshooting steps on your device but still issue not resolved. So, we would request you kindly visit the service centre and inspect your device with the technical team end, they will provide you with all the information in a better way after inspecting the device physically.
You can locate your nearest service centre with this given link: https://www.samsung.com/in/support/service-center/
jaswanthy
I am facing the same problem, any resolution?
