Slow charge for s24 ultra with samsung 45W charger
(Topic created on: 12-29-2024 11:04 AM)
ShivaNaveen
Hello Everyone,
I am facing slow charge issue for s24ultra with samsung 45w charger which I ordered from samsung official website only. (1.5 to 2 hours)
Cleaned charging port
Enabled fast charge in the mobile
Using original charger and cable.
Anyone facing similar issue?
Please suggest any solution?
With same charger s22 ultra is charging fast.
20 Comments
bhaas
Have you tried after reset mobile?
ShivaNaveen
No
bhaas
Please try once after taking backup. Will help you.
bhaas
It is better... If problem not solved... Once visit service centre.
ShivaNaveen
150 +gb data is in mobile, i got the s24 ultra in oct month only
mnh
Check in battery settings , is fast charging is enabled or not .?
ShivaNaveen
Yes
Hey shiva just clean your adaptor jack and phone jack I have same issue 🙂
ShivaNaveen
Done
