Charging issue
(Topic created on: 05-05-2025 01:18 AM)
bad_enzyme
I have a Samsung S23 Ultra. When I plug it in to charge, it automatically stops charging for a few seconds and then starts again. (I'm using Samsung's official 45W charger.) I have been facing this issue since I purchased it (January 24, 2024). I went to the service center many times, but it could not be diagnosed.
7 Comments
Subirhelps
S23 ultra???
After the one ui 7 update ??
bad_enzyme
Yes S23ultra
Since Jan 2024 when i purchased it
Wodehouse
Change the charger and check.
If this reply answered your query please tap 3 vertical dots to the right of my reply and tap "Resolved". Thank you 😊
bad_enzyme
I already did it, but nothing happened.
SPS23U
Same issue i have been facing...i have observed most of the time either charge or Phone is very hot, so it stopped the charging
cs_member8
Dear Samsung Member,
We have highlighted your concern to the dedicated team for further discussion on the case. They will contact you as soon as possible. You are our valued customer, and we appreciate your patience in this regard. We assure to provide you with the resolution as per the Samsung guidelines.
sameer99903
Same issue i face since one week i think it's software glitch
