Samsung s21fe charging issues
(Topic created on: 04-29-2025 01:49 PM)
suryanh
While charging my device in afternoon the battery percent is increasing instead it decrease while charger is connect and some time it charges very very slow
Why....?
cs_member10
Dear Samsung Member,
● We always recommend to use genuine Samsung charger for charging your device.
● Check your charging cable (USB cable) for physical damage such as wear and tear, bent prongs etc. If it is damaged, then kindly visit your nearest service center to get it replaced.
● Kindly check the charger functionality with a different device or try to charge the same device with a different charger.
● Check charging: If rating is 15W or above: Kindly try to charge the device in a non-inverter socket.
● If you using normal socket: As a safety measure Fast charging may not support, while you are using the device hence, request you to keep the device idle and check the charging performance.
Note: Kindly open Device care from settings > Battery > Please tap on three dots (more option) at the top right hand side > please select settings > enable fast cable charging.
For Android 11: Kindly open Device care from settings > tap on Battery > tap on More battery settings > Fast charging > Turn on.
● Kindly follow the standard charging procedure. i.e. please charge the device in switched-off condition for 10 minutes.
● Turn off Wi-Fi, GPS, Bluetooth, etc.
Turn off unused functions like Wi-Fi, GPS, Bluetooth, and location settings when not using them: On the home screen swipe down the notification panel > Turn off Wi-Fi, GPS, Bluetooth, and other connectivity features when not using them.
● Kindly check if ''Multiple applications'' are running in the background of the device.
● When running multiple applications, the processor processes more tasks and as a result, additional heat is released from the device. This happens with most electronic devices (even computers/laptops), including the devices of other manufacturers. Close all the background running apps when not using them.
● Avoid usage of mobile phones during charging. Usage of the mobile phone when charging may cause slow charging issues. So we recommend you avoid the usage of the mobile phone while charging.
3. If you do not remember password then advise to reset (Forgot password) your Google account.
In case the issue still occurs, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send).
