Samsung S24 Ultra Signals drop issue.
(Topic created on: 02-20-2024 12:06 PM)
ZUS
I am using my samsung s24ultra but I am facing issue with network signals,the signals get dropped and I am left with no network and the same moment it gets back.
Is anyone else facing the issue or anyone have suggestions kindly let me know.
5 Comments
Zammi
Hope it will be fixed during this month's big update. Personally I don't face this problem, but I have seen some people complain. Have you tried disabling 5G (switching to 4G/LTE).
By the way, I have noticed VoWifi works very well in this phone (Compared to older models). So I guess issue might be related to Vo5G which is not stable yet in the middle east.
DespradoKW
I have the same problem while using 5g.
Currently try 4g only
MOQBALI
Expert Level 4
Me too
ahmedyaso
Yes did the same yesterday switched to 4g
Samsung_specialist
Try updating your mobile device's software by following these steps:
Step 1: Go to Settings > Software Update.
Step 2: Tap on Download and Install.
Step 3: Follow the on-screen instructions.
Check if mobile data is enabled on your device.
Force restart your device.
Reset network settings:
Step 1: Go to Settings and select General Management.
Step 2: Select Reset.
Step 3: Choose Reset Network Settings.
Step 4: Follow the on-screen prompts and tap Reset Settings.
Step 5: Tap Reset.
