samali1
11-05-2017 11:33 PM (Last edited 03-15-2019 02:21 PM ) in
guys i really give up with this useless phone i am having problem poor wifi signal all the time because of this issue i sold my first s8 plus again i bought another one but unfortunately same issue i really dont know what to do even Samsung seems not care about this issue
4 Comments
Shri2
11-06-2017 01:24 PM in
What is the wireless router you are using and are u facing the same issue on all the places you are connecting....when you are near the ap does it connect fine with full signal ?
samali1
11-06-2017 09:51 PM in
yes when i am near router its fine working but when i go little far from router the signal drop down but my other phone which is Samsung j3 2017 model works fine even far from router
samali1
Shri2
10-07-2018 12:09 PM in
is it a dual band router ? meaning does it work on 5ghz and 2.4 ghz ?
