S9 plus charging problem
(Topic created on: 07-23-2019 07:41 PM)
Shauryam
I have a Galaxy S9 Plus I am using the original charging cable cable on one side of the cable the phone fast charges but on the other side of the cable the phone shows cable charging
I have fast charging enabled in settings
When I try to connect the phone to my computer it connects and disconnects  rapidly
I have never dropped my phone into water but one day suddenly moisture detected message started popping and after that all this is happening
I have tried other cable that came with my S10 plus
But it was of no use
Please help me if someone had a similar issue
Not applicable
it costed 3200
Not applicable
it has in built fan and it will let phone cool while charging.
Not applicable
cool down
Not applicable
this is issue I am facing but no worries I have wireless charge it help me worry less about the cable charging
xdgone
getting a wireless charger is not a solution ..
human have two kidney both do the same task , so according to the previous user comment can we use just a kidney cause another one is malfunctioning.. thats not a solution . every one dont want to carry a wireless charger everywhere
the user confused because in quick panel instead of showing remaining charge time and fast charging it just showing cable charging , RIGHT !!!
there is no issues . it just a notification under quick panel menu that you are connected to charger .. it happens you need not to worry
post the snapshot after following the given below instructions
dial *#0228# and post the current value and average values in both conditions
means connect with both side each time and each time do check the values and post the screenshots
second thing you can do is
reset the battery and charging module
install ADB in your PC than open developer mode in your android , adb instructions are available in android.com how you can connect adb with developer mode for your phone
after adb connection established with your phone execute this command
adb shell dumpsys battery reset
this will reset and recalibrate the entire charging , port and battery module
Not applicable
bro I am giving advice that the device has wireless charging support and where on this earth are you comparing tech with the human body seriously
Shauryam
xdgone thanks bhai... it shows remaining time but it fast charges on only one side of cable while on otherside it shows cable charging
xdgone
lolz .. comparison with logic .. You should remember that when charger showing issue while using USB than there must be a solution given specific to the issue not an alternative to ignore the issue
Shauryam
shinchannohara1994 thanks bhai I have a wireless charger phone charges perfectly with it
Shauryam
but then too this is a problem
main part is I cant connect laptop with phone
