S9 plus charging problem
(Topic created on: 07-23-2019 07:41 PM)
Shauryam
I have a Galaxy S9 Plus I am using the original charging cable cable on one side of the cable the phone fast charges but on the other side of the cable the phone shows cable charging
I have fast charging enabled in settings
When I try to connect the phone to my computer it connects and disconnects  rapidly
I have never dropped my phone into water but one day suddenly moisture detected message started popping and after that all this is happening
I have tried other cable that came with my S10 plus
But it was of no use
Please help me if someone had a similar issue
32 Comments
DrAKKI
wireless charging....
Shauryam
I am really happy to tell you that my problem is solved after the update of August now charging works perfectly
thank you everyone
adilbadashaha
Bhai mai be same problem face kar raha hu yar.. exactly the same .. fast charging on one side and cable charging on other...  it started very recently .. what should I do bhai? Am I stuck with this till the next update?
