05-27-2025 09:12 AM in
Galaxy S- Mark as New
05-27-2025 03:35 PM in
05-27-2025 04:34 PM in
Galaxy SDear Samsung member,
9. Reset the device:
IMPORTANT:
• For this:
If the issue persists and bugs, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send).
