S9 plus charging problem
(Topic created on: 07-23-2019 07:41 PM)
Shauryam
I have a Galaxy S9 Plus I am using the original charging cable cable on one side of the cable the phone fast charges but on the other side of the cable the phone shows cable charging
I have fast charging enabled in settings
When I try to connect the phone to my computer it connects and disconnects  rapidly
I have never dropped my phone into water but one day suddenly moisture detected message started popping and after that all this is happening
I have tried other cable that came with my S10 plus
But it was of no use
Please help me if someone had a similar issue
32 Comments
sen001
Generally such problems are due to faulty cable. Since you have already tried different cable I think your charging port is faulty. Get it check it service center.
Shauryam
yes but how can the port be faulty
I tried cleaning the port Too
xdgone
if you connect your phone for charging using a PC or Laptop USB than obviously it will not function properly and charging issue will rise
cause USB power supply in PC or Laptop are less lower than what phone needed ...
about PC connection amd disconnecting. you need to re install the USB driver and in phone you need to setup proper permission as well as USB connection should be revoked
Not applicable
or better solution to get wireless charger
Shauryam
All the driver are installed
I am charging from Wall Adapter that came with phone Then Also on one Side of the cable it shows fast charging and when I charge from other side it shows Cable Charging
When I connect it to Laptop it connects and disconnects rapidly
please HELP!!!!
sen001
Try different USB side of your laptop. I think there is a problem with charging port.
xdgone
its ok than , you are confused due to the information displayed in you quick panel notifications of battery charging status
Not applicable
please purchase wireless charger.
Not applicable
dont use cable for charging the phone .
