S24 Ultra Battery indicator problem
(Topic created on: 05-31-2025 11:59 AM)
hrlptl
It isn't show more then 28 where actual percentage is 46.
And it shows charging indicator after disconnecting the charger until restart.
2 Comments
BiRdMaN
Yes, many users have reported experiencing similar problems. This can be due to the phone re-optimizing itself after the update or apps needing to be optimized for the new firmware.
Add apps to the "deep sleep" list to prevent them from running in the background and draining battery.
Clear app cache to remove temporary data that can impact performance and battery usage.
Resetting battery statistics can sometimes help.
Adjust background usage limits in Settings > Battery and device care > Battery > Background usage limits.
Choose options like "Put unused apps to sleep" or "Sleeping apps" to restrict background activity.
If you find this helpful, kindly accept it as a Solution. It helps others
Tap the 3 dots on my reply and select "Accept Solution." Thank you 😊
sachinkep
There is option since last charge you can choose that option 1748677341183.jpg
