S25 Ultra low light photos issue
(Topic created on: 02-09-2025 06:05 PM)
Gvvs
Does anyone feel S25 Ultra low light(indoor) pictures are more grainy and noisy?
With lot of expectations, i purchased S25 ultra and I am bit disappointed.
Should I modify any camera settings?
Please suggest.!
8 Comments
Ultra_Devil
Bhai itna post karne se pehle youtube hi dekh lete. Pura youtube bhara hua hai ki low light photos or videos ka issue hai
Ultra_Devil
Or ye aaj se nahi decade se aisa hi hai samsung m.. koi new nahi hai..
Ultra_Devil
Reset camera settings and search on youtube the best camera settings for S25 U.. you will find the best settings you need to set on your camera
Gvvs
Thanks for the feedback Brother. I have done that as soon as I got my phone. I don't have issue with daylight/outdoor photos. Main concern about indoor/lowlight only.
Wodehouse
Try using night mode and keep your phone rock steady. It will start a countdown once you tap the shutter release button.
If this reply answered your query please tap 3 vertical dots to the right of my reply and tap "Resolved". Thank you 😊
Gvvs
Thanks for the feedback. But that's not what I was expecting. I am expecting decent pictures in indoor with portraits.I am attaching a sample picture which has more grains in decent indoor lighting. I took similar picture at the same time with another brand phone and it performed very well.
So, I want to know if there any better settings or it is same for everyone. 20250205_130753_1000023289_1738741077.jpg
cs_member10
Dear Samsung Member,
At Samsung, we strive to ensure you have an excellent product experience. Our products undergo stringent global quality checks, and currently, there are no reported issues.
Please follow these easy troubleshooting steps which may help in resolving this issue:
● Reset the camera settings: Tap on Camera>Settings>Reset settings>Reset.
● You can reset your device by following the steps:
3. If you do not remember password then advise to reset (Forgot password) your Google account.
Path: Settings> General Management.>Reset>Temporary cloud backup or External storage backup>After backup tap on Factory data reset to reset your device to its factory default settings.
If the issue persists, kindly report the problems with a log file. To share a log file, Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send.
tictaktoe
This is the problem with whole s series so called premium range
You should consider return instead of having false hope regarding uncertain software updates, the camera quality doesn't justify the high price It feels like Samsung has failed to innovate and improve its camera performance for premium devices over the past few years.
