12-05-2024 05:15 PM in
Galaxy S- Mark as New
12-05-2024 05:21 PM in
Galaxy STo troubleshoot this issue, you can try a few things. First, ensure that your phone's software is up-to-date, as Samsung has been releasing updates to address various issues.
Additionally, you can try disabling the "RAM Plus" feature, which some users have found to cause performance issues. To do this, go to *Settings* > *Device Care* > *Memory* > *RAM Plus* and toggle it off.
If these steps don't resolve the issue, it's possible that there's a hardware problem with your device. In this case, you may want to consider contacting Samsung support or visiting a authorized service center for further assistance.
It's also worth noting that some users have reported success with resetting their device or performing a factory reset. However, this should be done as a last resort, as it will erase all data on your device.
Please do check these links below
https://www.androidauthority.com/samsung-galaxy-s24-problems-fixes-3429319/
https://us.community.samsung.com/t5/Galaxy-S24/Screen-went-out-on-S24/td-p/2793224
https://us.community.samsung.com/t5/Galaxy-S24/S24-Ultra-Unresponsive-Black-Screen/td-p/2814573
If this reply answered your query please mark my reply as "resolved" by clicking 3 vertical dots on top right of my reply. Thank you 😊
12-05-2024 05:27 PM (Last edited 12-05-2024 05:27 PM ) in
12-05-2024 05:28 PM in
Galaxy SIf this reply answered your query please mark my reply as "resolved" by clicking 3 vertical dots on top right of my reply. Thank you 😊
12-06-2024 09:25 AM in
Galaxy SDear Samsung Member,
As per your concern, we would request you kindly perform the following steps to resolve your issue.
● Remove the screen protectors and cover from the device once and check the issue after restarting the device.
Path: Press the power and volume down keys simultaneously for a few seconds.
● Clear app cache through Device care:
Settings > Device care > Storage > CLEAN NOW.
● The clear cache memory of a particular application:
Settings > Apps > Now pick the app you like to clear off the cache memory > Storage > Clear Cache.
● Reset the device Settings: Settings > General Management > Reset settings>Reset all settings to their default.
● Enable/ Disable sensitivity touch: Settings> Display >Touch sensitivity.
● Check space availability: Settings > Device Care >Storage.
● Keep your app updated: Tap on Google Play Store app or Galaxy Store> Manage apps & device> Apps available to update> If you want to update apps individually, tap See details and then tap the Update button next to the app you would like to update.
In case the issue still occurs, please visit the service centre for a physical inspection of your device. You can locate your nearest service centre with this given link: https://www.samsung.com/in/support/service-center/
12-08-2024 12:12 AM in
12-24-2024 01:47 AM in
