10-18-2023 09:48 AM in
Galaxy S- Mark as New
10-18-2023 09:55 AM in
10-18-2023 03:32 PM in
10-29-2023 11:52 AM in
Galaxy SDear Samsung Member,
As per your concern, kindly perform the following steps to resolve your issue by the given link.
https://www.samsung.com/in/support/mobile-devices/my-galaxy-device-is-not-fast-charging-how-do-i-fix...
Kindly perform the following steps to resolve your OTG connection issue.
1. Check different OTGs with your device.
2. Check another pen drive.
3. Check with genuine OTG cable.
4. Check whether the device is OTG compatible or not.
5- Check the USB connection: Perform interactive checks through the Samsung Members apps.
Path: Samsung members > Support> Interactive checks > Charger/USB).
6 -Clear data of USB settings: Setting > Apps > Three dots (Appearing at the top right corner) > Show system apps > Search USB Settings > Tap on storage > Clear data of USB Settings.
7- Reset app preferences: Settings > Apps > Three dots (Appearing at the top right corner) > Reset app preferences (It'll reset the permissions of all applications)
Reset your device: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-mobile-how-to-perform-a-factory-res...
Kindly share the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
Samsung Customer Support.
