How-to solve battery draining issues in samsung galaxy
(Topic created on: 12-11-2023 08:18 PM)
adit_mikku_
1. Turn off nearby scanning.
For that - go to settings>connection(scroll down)>more connections>turn off "nearby scanning".
2. Turn off print services.
For that- go to settings>connection(scroll down)>more connections>click printing>turn off default printing services.
3. Adjust screen refresh rate to 60hz.
4. Use black theme for amoled or oled. displays, it will save more power.
5. Turn off data roaming.
For that- go.to settings>mobile networks> turn off data roaming.(Tip- if u want to save more power turn off volte call feature just below that.)
6. Go to settings>battery and device care>battery(scroll down)>more battery settings>enable adaptive battery.
●Tip(Charging ur phones battery from 20-80% will increase ur battery health🔋. Don't charge it full. Turn on ("protect battery") in settings so that ur phone will automatically stop Charging at 85%.
Cleaning phone caches weekly will improve device efficiency.
Hope this helps😁
Thank u
17 Comments
Corgi
It's nice to see posts like these.
adit_mikku_
Thanks bro hope this helps 😁
umesh30
And also these:
● Don't use fast charging mode regularly. It's really affecting the battery life.
● Turn off unnecessary alarms and reminders.
● Turn off automatically syncing (use manually syncing when needed)
● Disable background data of heavy apps.
● Turn on power saving mode while using wifi.
ShubhamJ123
haan bhai sb khuuch hi bnd krde ..meri maan to phone hi power off krde
adit_mikku_
umesh30
To fir SoT time ki sikayat bhari post kyo dalta he bhai... 😅
Ye to tips batai he, forcefully kaha follow karne ko bol raha hu 😅
ShubhamJ123
Sorry bro background data disable krne ki wajah se tumhare reply ka notification late aaya...
umesh30
It's ok bro.. 😊
cs_member10
Dear Samsung Member,
We appreciate you taking the time to share valuable comments and information with us. kindly feel free to get in touch with us if there is any issue regarding the Samsung.
