Problem with back glass of S24 ultra.
(Topic created on: 07-30-2024 08:08 PM)
vjpooja
Do anyone has the same problem with back glass. I never stick any back glass and never splash water on it... Samsung says we don't have any solution for it.....
19 Comments
cs_member10
Dear Samsung Member,
As per your query, we request you kindly visit the service centre for a physical inspection of your device. So that they can check the exact issue with the device and fix it at the earliest.
You can locate your nearest service centre with this given link: https://www.samsung.com/in/support/service-center/
vjpooja
I already been there and got very hard response that "sorrywe can't do anything about it u have to pay for the price to change the back panel"..
Naveen0808
Same issue my mobile
Naveen0808
Now what happened bro
They replaced new one a..?
AamirKhanKmr
Same issue i am also facing in my Samsung S24 Ultra
vjpooja
Go for glass change from Samsung if it's within warranty.
San_Sanvir
I have the same problem. Did you accidentally drop you phone?
vjpooja
No never.
sagarhmg
I am also facing the same issue, is ours solved? Did you pay for that?
