Galaxy s24 ultra fingerprint not working problem solved
(Topic created on: 04-29-2025 09:17 PM)
parag8
If u apply any of the glass protector the fingerprint does not work properly.. Cause in s24 ultra fingerprint scan is ultrasonic fingerprint scan for security reasons .. U have to use a plastic type thin flexible protector.. U have to by it from local store..i bought it for 100 rs on local mobile store.. Because Online price are very expensive for this..
After applying this u have reset ur fingerprint..
Then after your fingerprint sensor will works smoothly..
If ur problem solved like my post
4526j8😂
