My s10 lite proximity sensor issue how to fix it
(Topic created on: 06-03-2023 07:32 PM)
Anand140012
Beginner Level 3
Is done service or update to fix it
3 Comments
Not applicable
Turn off the option- double tap to screen off
userA178
It could be some sensor error
Give this to service centre
cs_member10
Dear Samsung member,
We acknowledge your query and apologize for the inconvenience caused to you and will surely assist you regarding the same and please follow the easy troubleshooting steps which might help to solve the issue.
1. Proximity sensor:
It is placed near the earpiece of a phone. During a call, this sensor lets the system know that you're most probably in a call and that the screen has to be turned off.
1. From a Home screen, tap Phone (lower-left).
2. Tap Menu.
3. Tap Call settings or Settings. If needed, tap Call on the settings page.
4. Tap Turn off screen during calls to enable or disable. Enabled when a checkmark is present.
2. If the still issue persists, kindly remove accessories.
Protective films, cases, stickers, or glass screen protectors can block the sensor. Only use Samsung-approved accessories.
Clean the sensor with a soft cloth.
The proximity sensor is located at the top of the phone, its exact position will vary by model. Clean the front of the device with a clean, soft cloth.
Update software: Menu>apps>settings>software update>install.
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
Thank you for writing to us.
Samsung Customer Support.
