Resolved! Solved
Proximity sensor issue on s23 ultra
(Topic created on: 02-11-2025 07:02 PM)
sathvik98
From last week onwards the proximity sensor on my phone being activated while playing games and performing normal tasks after sometime it's again normal why is that it's so irritating
Give me some fixes to the problem @samsungsupport
goodthings
Please reset all settings of your's device in general management settings also Flight ✈️ mode on n off one time also optimize your's device in device care too also clear catche of all apps manually then try to it's again. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
3 Comments
goodthings
goodthings
Your's most welcome to here.
cs_member10
Dear Samsung Member,
We request you kindly share the log file. Also, share the video clips and images for better understanding. This will help us to investigate further and resolve this issue.
To share the log file: Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.
