Resolved! Solved
S23 proximity sensor issue and 4 gray dots
(Topic created on: 12-29-2024 03:04 PM)
vivekkk07
I have an S23. Four gray dots are visible on the top right side. This mainly happens during calls and on the lock screen; it flickers continuously during calls and sometimes on the lock screen.
Wodehouse
The four gray dots you're seeing on your S23 are likely related to the proximity sensor. This sensor is usually located behind the display and turns on during calls to detect how close the phone is to your ear.
When the infrared LED is activated, it can appear as four small squares or dots on the screen, especially against a white or light background. This is a common phenomenon and not a defect.
The flickering you're experiencing during calls is probably due to the proximity sensor constantly checking the distance between the phone and your ear. It's possible that the sensor is more sensitive or active during calls, causing the dots to flicker.
To confirm, you can try making a call in a well-lit area and see if the dots appear. If they do, it's likely the proximity sensor at work.
Please do check these links.
https://eu.community.samsung.com/t5/galaxy-s23-series/s23-proximity-sensor-screen-mark/td-p/7755487/...
https://eu.community.samsung.com/t5/galaxy-s23-series/weird-icon/td-p/10540087
https://xdaforums.com/t/4-pixels-are-visible-while-calling-and-having-a-white-background.4553567/
If this reply answered your query please tap 3 vertical dots to the right of my reply and tap "Resolved". Thank you 😊
4 Comments
vivekkk07
Wodehouse
vivekkk07
Thank you, brother, for explaining; you explained better than Samsung customer care.
cs_member10
Dear Samsung Member,
We would like to inform you that the four dots displayed at the top of your device are related to the proximity sensor. It is designed to turn the smartphone display black during calls, which is a standard feature built into the device.
If you have any further questions or need assistance, please do not hesitate to reach out.
