Is it safe to use samsung 45w pd charger with samsung s23 base model?
(Topic created on: 07-20-2023 01:57 PM)
sukkhy_Galsian
Beginner Level 5
Hi Everyone, have recently bought samsung galaxy s23 base model, but, haven't bought 25w charger because I've already got samsung 45w pd charger which I use for my tab s8. I want to know, is it safe to use 45w pd charger with s23 base model or I should buy 25w charger?
10 Comments
yashwanth1
I use the 25w for my s23ultra...45w is safe to use as well for s23 series .
hake22
You can safely charge with 45w.
Yes
Yes
imanandkumar
You should buy 25W charger if want your device safe
sukkhy_Galsian
Beginner Level 5
But why, everyone is saying that it's safe to use even I'd asked the customer executive while buying the phone and he'd told me that if it's a pd charger then it's safe to use for my s23.
Anikroyale
It is perfectly fine to use your 45 watt PD charger with the Galaxy S23. It is a PD charger, so it won't cause any damages.
DrQaisar786
Sir, I am using 45 W and even a 100 w laptop charger for my S 21 ultra & S22 Ultra since one and a half year approx. it's working fine for me....
Never faced any battery issue.
sarnandu
45W
