2 weeks ago in
Galaxy S- Mark as New
2 weeks ago (Last edited 2 weeks ago ) in
Galaxy S1. Hard reset your device
2. Don't copy apps from drive
3. Turn off adaptive battery
4. Uninstall/disable the default apps that you never use.
5. Use your phone in light performance mode
6. Set Display to FHD+ from QHD+
7. For more improvements from samsung, wait for upcoming updates.
2 weeks ago in
2 weeks ago in
2 weeks ago in
Sunday in
2 weeks ago in
2 weeks ago in
2 weeks ago in
Galaxy SDear Samsung member,
9. Reset the device:
IMPORTANT:
• For this:
If the issue persists and bugs, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send).
