06-05-2025 11:15 PM in
Galaxy S cs_member10
			cs_member10
06-06-2025 11:17 AM (Last edited 06-06-2025 11:18 AM ) in
Galaxy SDear Samsung Member,
● Reset the camera settings: Tap on Camera>Settings>Reset settings>Reset.
● You can reset your device by following the steps:
3. If you do not remember the password then advise to reset (Forgot password) your Google account.
Path: Settings> General Management.>Reset>Temporary cloud backup or External storage backup>After backup tap on Factory data reset to reset your device to its factory default settings.
If the issue persists, kindly report the problems with a log file. To share a log file, Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send.
06-23-2025 06:15 PM in
