Display problem in my s10 lite
(Topic created on: 12-11-2021 03:37 PM)
kovaiGuru
I bought my s10 lite in2020 but by display has a burn problem i.e my aod turns red in colour amd black colour is not visible in my display
I think samsung is planning this to use a mibile for a year and need to change to another brand or samsung will solve this to me..........
I am worried because my 43,000 works for a year and nit for 10 years atleast🙄🙄🙄
13 Comments
BVikram
Screen burn is common for AMOLED panels. Tv's have pixel shift feature to prolong the life upto some extent. But in mobile no such feature Implement. Hope they add some kind for mobiles. As of now prevention only option is use medium brightness, disabled AOD, dark mode and use gesture navigation.
kovaiGuru
Hmmmm
RohanChaudhary
Beginner Level 5
Having same issue
GauravK21
Can you please elaborate this issue more briefly???
I think I'm facing this same issue ...
kovaiGuru
Okey......i was using my mobile a week ago one afternoon my mobile screen started to blink like no singnal......
Then it came to normal.....at first i taught i got hacked by someone...........after a day i noticed that my aod is in red in colour.........and i came to know that i did not got hacked instead my mobile got a screen burn.......and i can't see black colour..........and i am facing colour changes and that no signal issue.......sometimes...... 🙄 🙄 🙄
GauravK21
In my case Display sometimes turns to Greyish Color ....
kovaiGuru
Same screen burn effect is going to occur so change your back case dont use fully covered because heat produced need some vent and off the aod and keep your mobile in dark mode ....is the way to protect your phone....if you have warrenty go and get it from service centre. ........now i understood y people are getting iphone rather than getting android 🙄🙄🙄
GauravK21
TBH I'm not a huge Fan of iPhone ... iPhone S**ks...
I don't use any type of Cover on my Phone ...
kovaiGuru
I am also not a fan for iphone.........
🙄 but i have tried every brand did not try ios .......
Good....🙄
