Display problems
(Topic created on: 10-04-2023 08:56 PM)
SunilTheAdmin
Hey everyone, Do you know the S10 Lite Display price at services center? My Display has occurred issue in black color, Black not looking pure black it has little bit green tint.
7 Comments
sarnandu
check in samsung shop
Meliorist
Green Tint is a hardware issue
I also have S10 Lite from the past 3 and half years and it has a little bit of green tint at the top bottom left corner
I don't think so you should change your display for some old phone like ours
Instead save money and maybe you could buy other better phone coz our phone is already too old now ...
PankajS10Lite
Display from Samsung Authorize office will cost you around 11000/- including labour cost + GST etc.
I was also having the same issue and got my phone display replaced by paying.
cs_member10
Dear Samsung Member,
As per your query, We request you kindly visit the service center for a physical inspection of your device. So that they can check the exact issue with the device and fix it at the earliest. They will physically inspect your device and guide you on the exact cost of repair also you can check the screen cost on the given link:
https://www.samsung.com/in/support/spare-part-pricing-list-for-repair/#
You can locate your nearest service center with this given link:
https://www.samsung.com/in/support/service-center/
Mizfin
My display has white lines after latest update🥲
satishk7806
10700 k kreeb hai.
