Resolved! Solved
Display issue
(Topic created on: 07-30-2024 08:23 PM)
kushpvt
Firstly,my device is s23
It has been 2 months of purchase
The problem is
At downside of left corner a small portion is lightly whitish
As I googled it all says screen bleeding
But if screen bleeding is the cause it should be on both white and black colours of screen
But in my scenario on black colour it is completely fine👍
But on light colours it has the problem can anyone please help me???🙏
Also I have checked temper glass.No problem with it🙃
HELP...!!
Resolved!
67 Comments
NOMAĐ
Why did you accept it?? You should have told them it's not your fault and the device is just 3 months old.
kushpvt
I have told but if any damage is there then warranty will be void
So 9k is compulsory
Soo,,Iam thinking
kushpvt
Definitely brohh👍
aswinzzzz
Bro.. my s23 just correct after 1month got green filter on my screen suddenly... and took to service center... and screen got replaced🤢🤕
kushpvt
Is everything OK now??
aswinzzzz
Ys... hope nothing happens again😐😐.. that new buy bought feel is gone.. after the repair
kushpvt
Ohh!!any change in display??I mean any faulty service??
cs_member10
Dear Samsung Member,
As per your query, we request you kindly visit the service centre for a physical inspection of your device. So that they can check the exact issue with the device and fix it at the earliest.
You can locate your nearest service centre with this given link: https://www.samsung.com/in/support/service-center/
Not applicable
Don't take any risks phone is under warranty so resolve this problem in service centre
kushpvt
Yes brother,, I am thinking what to doo
