Resolved! Solved
Display issue
(Topic created on: 07-30-2024 08:23 PM)
kushpvt
Firstly,my device is s23
It has been 2 months of purchase
The problem is
At downside of left corner a small portion is lightly whitish
As I googled it all says screen bleeding
But if screen bleeding is the cause it should be on both white and black colours of screen
But in my scenario on black colour it is completely fine👍
But on light colours it has the problem can anyone please help me???🙏
Also I have checked temper glass.No problem with it🙃
HELP...!!
Resolved!
67 Comments
Anuragh13
Bro same defect noticed just now
pilotsandeep
I think it's happening due to the latest software update because everyone is having this issue from July onwards even me with the same problem ..Just going now to the samsung care service centre.
Anuragh13
Still got warranty for a month
kushpvt
Visit the service centre broohhh!!immediately
Anuragh13
Will they Replace it bro without any charges..?
kushpvt
Yes broh,,only if there is no liquid damage and physical damage
Anuragh13
Bro did you get your phone display replaced or are you continuing with the problem ..!?
kushpvt
Continuing for now,,soon I will visit some other service centre
Anuragh13
Bro did you get it replaced ..????
Shenron7
Is around your Punchhole camera also glowing and showing the same issue?
