Resolved! Solved
Display issue
(Topic created on: 07-30-2024 08:23 PM)
kushpvt
Firstly,my device is s23
It has been 2 months of purchase
The problem is
At downside of left corner a small portion is lightly whitish
As I googled it all says screen bleeding
But if screen bleeding is the cause it should be on both white and black colours of screen
But in my scenario on black colour it is completely fine👍
But on light colours it has the problem can anyone please help me???🙏
Also I have checked temper glass.No problem with it🙃
HELP...!!
Resolved!
67 Comments
NOMAĐ
I'm glad I could help
kushpvt
NOMAĐ
Thanks for accepting as solution
kushpvt
Broo another doubt ,,did you guess any liquid damage in my phone((guess))see image???
kushpvt
Ur Welcome broo🤎
NOMAĐ
I think I made you think that there might be water damage. Don't worry about it.
Just visit a service center tomorrow and report the issue. Have the photos of the issue in hand. They will sure inspect it and will tell you if it's water damaged. But that won't be the case as far as I know.
Be firm in making them replace it.
NOMAĐ
Also don't ask them to check if it's water damaged. They may use it against you.
Just give them the phone and tell them that it's a manufacturing defect that's noticed late. Be firm.
kushpvt
I hope I will do it
NOMAĐ
Did you go to service center
kushpvt
Broo I visited the service centre
They told me it should be replaced ..the fact is they told part takes 3days to come...we will keep your device for 3day..I was shocked....another thing they told me that if any thing is damaged inside... warranty will be not claimed and should pay 9k....then asked that if damage is found then keep my old screen I don't need any replacement..again they told me once we remove the screen old one cannot be replaced so I should pay 9k...I was shocked and came to my home with my phone
