Resolved! Solved
Display issue
(Topic created on: 07-30-2024 08:23 PM)
kushpvt
Firstly,my device is s23
It has been 2 months of purchase
The problem is
At downside of left corner a small portion is lightly whitish
As I googled it all says screen bleeding
But if screen bleeding is the cause it should be on both white and black colours of screen
But in my scenario on black colour it is completely fine👍
But on light colours it has the problem can anyone please help me???🙏
Also I have checked temper glass.No problem with it🙃
HELP...!!
Resolved!
67 Comments
kushpvt
Okay broo👍thanks
kushpvt
Free of cost??,,I have warranty
somanath_sahu
Yess bro you're using S series, so you should get premium service of samsung
kushpvt
Okay bro👍
goodthings
Kindly complaint to Samsung customer support through Samsung Members App as error report also send log files Along with this error report for this issue. Then go to service center for resolves this issue. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
kushpvt
Okay broo👍
goodthings
Your's most welcome brother.
Dini256
Hi, I also had the same issue a few days back, on the left, right, and top corners. I visited the service center, and they checked and confirmed some water was found in the display.
kushpvt
So what they did??broo
What's up phone model bro??
How they fix it??
Dini256
Replaced with a new display, without warranty.
