Battery post-replacement
(Topic created on: 01-20-2024 11:17 PM)
heytanix
Hello Samsung community!
I am Thanish,
I bought a S20 FE(Exynos edition) in 2021 February,
Now the battery was used enough and in the Samsung members app it showed up as "weak" in status now I have got a replacement done and even with the new battery inserted it shows up as weak
6 Comments
iamrohitkm
Don't worry about that. I have heard from service center guys that even after battery replacement, it will show the same. Don't believe that always visit service center and get it inspected from their tools.
heytanix
Yeah I did that on their computer it says it's good but samsung members won't show the same...
cs_member10
Dear Samsung Member,
As per your query, we request you kindly share the log file. This will help us to further investigate and resolve this issue.
To attach the log file: Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
Aishwarya0918
What was the cost of battery replacement? As i have s20fe 5g version, & feels like the battery got swollen
sunjay98
It's probably not swollen It's just the back panel which came out may be because of weak glue.
Jst get is pasted.
Everything thing will be well🙂
John282
Same😂
