Zree
07-22-2023 11:00 AM in
Hi,
I am facing battery drain issue on my S23 after last 2 updates . Overnight battery drain with only wifi turned on is 15-20%. Thats a big drain . Please fix this issue or suggest something better .
3 Comments
VikrantTambade
07-22-2023 05:50 PM in
Hi,
It is recommended to wipe your cache partition through recovery mode after every update. Give it a try and check.
Infinity53
Expert Level 4
07-23-2023 05:07 PM in
If your Samsung Galaxy S23 Battery life drains faster than usual, you can start by checking the Battery Usage. You can check to see which apps consume too much power. Close or uninstall the misbehaving apps.
ojwh
08-10-2023 01:15 PM (Last edited 08-10-2023 01:17 PM ) in
Check battery usage. Uninstall any apps you don't really need which drain the battery. Enable the power saving mode in settings. Give the phone sometime to learn your usage patterns to be able to auto set. Set optimization for apps you don't need running all the time, turn on data saver. Use Bixby Routines or Bixby Routines + to optimize your phone overnight [turn off unused functions, etc].
I hope these can help.
![](/skins/images/69EAC8139A6AAA18E636162C8C84A9BA/responsive_peak/images/icon_anonymous_message.png)
