Severe Battery Drain Issues on Samsung S24 Ultra
(Topic created on: 07-08-2024 01:52 PM)
itsnithin
Dear Samsung Support,
I am experiencing severe battery drainage issues caused by Google Play services and the Samsung built-in app "Contact Storage." Screenshots of the issue are attached for your reference.
I have noticed that multiple users have reported the same issue on the Samsung forum since the beginning of this year. Unfortunately, the Samsung team has been responding with generic template messages without addressing the real issue. Here is the link to the forum discussion: Samsung Forum Link.
I also visited a Samsung repair center, where I was informed that many users are facing the same problem. Despite the service center's efforts, including sharing logs and installing the latest OS, the issue persists, and they are awaiting a response from the Samsung team.
The severe battery drain and overheating are causing significant concerns about the battery's health. I am seeking immediate attention to this matter, as the phone's battery life and health are seriously affecting my daily life. One of the main reasons I chose the S24 Ultra was for its battery performance, but now the situation is the opposite.
Please provide an urgent solution to this issue.
25 Comments
Can u chg your battery Protection to adaptive and restart your mobile and see then what's happens
itsnithin
No use . Already tried
Which all 3rd party apps you have downloaded recently 🤔
itsnithin
Only play store apps
Did u restore your phone completely and tried ?? If yes no other option Samsung should fix it
itsnithin
Yes did twice . No use
So many Samsung users are facing same issue from February onwards
No help from them
Is it not under Samsung care+ they should fix it
itsnithin
Yes they are still figuring it out for a week no solution
GalaxyNerd
Are you using microG apps such as vanced YouTube?
