charging problem
(Topic created on: 04-30-2020 03:15 PM)
ankush1990
Galaxy Note
I have seen a big problem in Samsung Galaxy models i.e.GT-5830,Grand-2,J-2,Note-8,M-30,A50 and Note-9. Its a charging problem, when my device battery falls down to 5% and i put it on charge then its not possible to have full 100% battery... it is a big problem by SAMSUNG..."using its original charger". THANKS... #SAMSUNG #aajtak #bug #samsungproblem #divyabhaskar #telecommunications #samsungmobile
4 Comments
Anikroyale
Galaxy Note
What are you exactly trying to say? There is no problem in my devices...which I use, I used to have a Note8, that did not have any charging issue. 2hat is tour exact problem?
ankush1990
Galaxy Note
low betri
cs_member9
Galaxy Note
Dear Samsung Member,
Kindly follow the below mentioned step to improve the performance of the device:
Check device in safe mode: Using Safe Mode on a Samsung phone or tablet allows you to force the device to run the essential operating system, and disable most 3rd party applications.
Enter safe mode: Press and hold the Power key, when Power off icon appears.>Press and hold the power off icon.
Exist safe mode: Press volume down and power key simultaneously for 5 seconds to restart the device.
Note: If your device functions correctly in Safe Mode, it is most likely that the issue lies with a 3rd party application that can be uninstalled to resolve the problem.
Battery related Concern: For more information, you can also follow given link:
https://www.samsung.com/in/support/mobile-devices/samsung-mobile-battery-drain-issue/
For further assistance, register your concern in Samsung Members Application (Samsung Members App > Feedback >Error report > Attach log file for any issue)
