Samsung note 10 lite network & wifi problem...
(Topic created on: 07-22-2022 03:00 PM)
sabbirahamedabir
Galaxy Note
Samsung note 10 lite network & wifi problem...any solution?
3 Comments
cs_member8
Galaxy Note
Dear Samsung member,
We acknowledge your query and apologize for the inconvenience caused to you and will surely assist you regarding the same and please follow the easy troubleshooting steps which might help to solve the issue.
Kindly restart your smartphone once and also re-insert your SIM card.
Check device network in an open area: Kindly check your device in a different location/network coverage area.
Check device network mode settings
Please follow the below steps.
Step1: Navigate to the app's screen and tap on Settings.
Step2: Tap on Connections.
Step3: Tap on Mobile networks.
Step4: Tap on network mode SIM1 or SIM2.
Step5: Select network mode.
Note: We recommend setting device network mode as LTE/3G/2G (auto connect) mode.
Kindly do check the same SIM card in another phone or another SIM card on the same phone to verify the issue.
Please follow the easy troubleshooting steps which might help to solve the wifi issue.
Note: Any prompt that says "Authentication Error" is related to an incorrect password. Please contact your Internet Service Provider for assistance regarding changing your Wi-Fi network password.
1: Settings >> Connections >> Wi-Fi >> W-Fi network >> Tap and hold the Wi-Fi network that you're having trouble with until the menu allows you to select Forget Network.
2: Reset Network Settings: Setting >> General Management >> Reset >> Reset Network Setting.
3: Restart the Router and Mobile Device. Switch off your Router (at the wall or with the power button on the router) and wait for 2-3 minutes before switching it on. While you're waiting, press the Power button on your mobile device and select Restart.
Once the router has been successfully connected to the internet again, try to connect to your network on your mobile device.
Make sure there is no interference between the router and your mobile device. Concrete walls, fridges, and microwaves can all interrupt the Wi-Fi signal.
4: Disable flight mode. Find the Airplane/Flight mode option and turn it off.
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
atjun
Galaxy Note
Samsung note 10 lite network wifi problem
Members_y8qAeTS
Galaxy Note
same problem wifi is not working
