Battery issues
(Topic created on: 04-02-2025 11:12 PM)
sanjay81
Beginner Level 4
Galaxy Note
Am using galaxy note 20 ultra since 4 years. I had display issues and got it replaced with new display set .While collecting back my device from service centre I was informed that they replaced my battery too with new battery as that's mandatory ,for free though.But since then I had been facing battery drain issues and now it shows that my battery is weak. i approached the service centre before 6 months only to be sent off saying that it can be mother board issues as the battery was recently replaced so there can be no issues in battery.This is really pathetic that my battery was replaced without any information nd now when m facing issues there is no proper response.What do I do?
6 Comments
Anirban_C_Dip
Galaxy Note
Direct ask them why They replaced the Battery without asking your permission.... Sometimes 1 or 2 unit of hundred unit batterys might be faulty ... But without asking owners permission is kinda felony to me🤷 ♂.. I might be wrong but, I'd suggest to contact another service centre or 3rd party to check the device.
RajathSR
Galaxy Note
if the battery replacement is mentioned in the bill, then you have all rights to claim compensation for it
either tag them in social media and question them the same
or go to a different service centre and explain the issue
goodthings
Galaxy Note
Kindly complaint to Samsung customer support through Samsung Members App as error report also send log files Along with this error report for this issue. Then go to service center for check and resolves this issue . If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
Galaxy Note
Your's most welcome to here.
cs_member10
Galaxy Note
Dear Samsung Member,
As per your query, we would request you visit the service centre where your product was previously serviced. They will provide you with all the information in a better way after inspecting the device physically.
Galaxy Note
59😮
