Battery Issue
(Topic created on: 09-17-2025 12:40 AM)
Prajeeshpandi
Galaxy Note
The battery is drained fast , how much would be the replacement cost at Samsung repair ccenters .
5 Comments
ghingur
Galaxy Note
I am facing battery problem on Samsung galaxy a35.
Kuldeep_Rvl
Galaxy Note
Do not change the battery. Wait for oneui8 stable
goodthings
Galaxy Note
Kindly complaint to Samsung customer support through Samsung Members App as error report also send log files Along with this error report for this issue and go to service center for check and resolves this issue also check price on Samsung website too. If you like please accept as a solution it's help to others users also,click on 3dots in my reply section and click on accept solution . Thanks.
goodthings
Galaxy Note
You're welcome to here.
cs_member10
Galaxy Note
Dear Samsung member,
3. Check device network fluctuation. Avoid usage in areas with low network/fluctuation.
9. Update software: Go to Settings > Software update > Download and install > Check for software update > If Software update available > Download > Downloading updates > Install now
10. Reset the device:
IMPORTANT:
• For this:
If the issue still persists, after performing all troubleshooting steps, would request you to please visit the service center. Below is the link to find nearest service center
http://www.samsung.com/in/support/servicelocation/
