Battery drain issue
(Topic created on: 10-07-2025 09:32 AM)
VampireDev
Galaxy Note
I’ve been using my S24 Ultra with One UI 7, and I was really happy with the battery life. But ever since I updated to One UI 8, I'm now struggling with battery drain problems. I'm really worried about it... Is there any way to fix this? I just want to revert back to One UI 7. Is that even possible? 😣
2 Comments
BiRdMaN
Galaxy Note
Send an error report along with log files to customer support through this members app, and Samsung will add/fix it in the next update. To do that, follow this procedure
Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.
If you find this helpful, I'd appreciate it if you could ACCEPT it as a SOLUTION. Thank you 😊
cs_member10
Galaxy Note
Dear Samsung member,
9. Reset the device:
IMPORTANT:
• If you do not remember it, then reset (Forgot password) your google account.
• For this:
• Open Gmail (https://accounts.google.com/servicelogin) > forgot password >Select ""try another way"" > Next > Enter a new password > Next.
Please follow the below steps to reset the device: Settings > General Management > Reset > Temporary cloud backup or External storage backup > tab on Factory data reset (This will erase all data, including files and downloaded apps)
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send).
