Battery draining issue
(Topic created on: 12-10-2024 04:45 PM)
KarthiNigam
Galaxy Note
Hi All,
Is anyone facing battery draining issue with s24 ultra, after the update of November security update.
7 Comments
Galaxy Note
Me
Not applicable
Galaxy Note
Yes there is battery drain issue
goodthings
Galaxy Note
goodthings
Galaxy Note
Your's most welcome to here.
cs_member10
Galaxy Note
Dear Samsung Member,
As per your concern, we would request you to kindly perform the following steps to resolve your issue by using the given links.
● Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send.)
Jahaji
Galaxy Note
Me
Galaxy Note
Me also
