GALAXY Note 20 Ultra battery issues
(Topic created on: 05-09-2025 06:56 PM)
Rocky181
Galaxy Note
Dear Members,
 I had green line issue on my Note 20 Ultra after several discussions and escalations Samsung agreed to change my screen and Battery after that was done my phone battery was draining faster than my original one, when informed service center they asked me to use it for some time but there was no change in battery performance. Nobody at Samsung was ready to take the responsibility now past 1 year the battery shows weak on diagnostic. Significant fraud happening while you handover the phone to Samsung service center. Did anyone face battery issues after display change?
Any idea how much do they charge for new battery?
2 Comments
cs_member8
Galaxy Note
Dear Samsung member,
3. Check device network fluctuation. Avoid usage in areas with low network/fluctuation.
9. Update software: Go to Settings > Software update > Download and install > Check for software update > If Software update available > Download > Downloading updates > Install now
10. Reset the device:
IMPORTANT:
• For this:
If the issue still persists, after performing all troubleshooting steps, would request you to please visit the service center. Below is the link to find nearest service center
http://www.samsung.com/in/support/servicelocation/
Rocky181
Galaxy Note
Thanks for your response but I clearly understand your failure to address the concerns, in the first place you guys changed my battery to another old or damaged battery since then it's giving problems
