Network issues after battery replacement.
(Topic created on: 08-16-2024 04:15 PM)
_Junaid
Galaxy Note
Hello, I'm using my galaxy note 20 since 3.5 years and everything was working fine except I'm facing battery drainage issue as the battery got weak after heavy usage. Recently I changed my battery from an authorized Samsung service center and after that I'm facing network issues.
My phone shows emergency calls only where in my office where I used to get good to fair network. Did someone faced the same issue and what's the solution?
Thank you.
5 Comments
saketh123
Galaxy Note
Hello I am using samsung flip5 since 1 week I have updated to esim where all the banks where registered to that number now the app cannot recognize the Sim what is the solution
_Junaid
Galaxy Note
Go to the Jio/airtel/VI gallery and buy a physical SIM, Within 2 hours, your ESIM will go off, then delete the ESIM and put in the physical SIM. It'll work most probably. If it doesn't, then your network provider or Samsung Care will help. If it's important for you to use esim only, ask Samsung support for help or visit a service center.
goodthings
Galaxy Note
Please reset network setting of both Sim one by one and than reset all settings of your's device in general management settings also Flight ✈️ mode on n off one time, restart your's device without any Sim in slots,interchange Sim in slots, turn off power saving mode then try to it's again. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
Galaxy Note
Your's most welcome to here.
cs_member10
Galaxy Note
Dear Samsung member,
As per your query, kindly follow the easy troubleshooting steps which might help to solve the issue.
Note: kindly contact your network service provider once to make sure there is no issue from their end.
Check device network in open area
Check device network mode settings
Please follow the steps: Navigate to apps screen and tap on Settings>> Tap on Connections>> Tap on Mobile networks>> Tap on network mode SIM1 or SIM2>> Select network mode
Note: We recommend to set device network mode as 5G/LTE/3G/2G (auto connect) mode.
Check network operator settings
Kindly set device network operator as "Automatically".
Please follow the steps: Navigate to apps screen and tap on Settings>> Tap on Connections>> Tap on Mobile networks>> Tap on Network operators>> Select automatically>>
Note: We recommend to set device network operators as automatically.
Tap on OK>>Registered on network.
Check SIM cards
Kindly do check same SIM card in another phone or another SIM card in same phone to verify the issue.
Update device software (If Software update available): https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-smartphone-how-to-update-software/
Reset the device: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-mobile-how-to-perform-a-factory-res...
