Battery drain Note 10 lite
(Topic created on: 02-01-2025 12:41 PM)
SatyaTrip
Galaxy Note
How to fix battery draining issues in Galaxy Note 10 lite
4 Comments
goodthings
Galaxy Note
Kindly reset factory data with backup then try to it's again. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
Galaxy Note
Your's most welcome to here.
cs_member10
Galaxy Note
Dear Samsung member,
9. Update software: Go to Settings > Software update > Download and install > Check for software update > If Software update available > Download > Downloading updates > Install now
10. Reset the device:
IMPORTANT:
• For this:
If the issue still persists, after performing all troubleshooting steps, would request you to please visit the service center. Below is the link to find nearest service center
http://www.samsung.com/in/support/servicelocation/
PranavvB17
Galaxy Note
I changed my battery twice and still facing the same issue. At the service center they are telling that it's a motherboard issue.
