01-24-2021 08:33 AM in
Galaxy MSolved! Go to Solution.
4 Solutions
01-24-2021 08:50 AM in
Galaxy M- Mark as New
01-24-2021 11:12 AM in
Galaxy M2 Turn off auto wifi hotspot 2.0
3 Turn off wifi on automatically
4 Turn off nearby device scanning
5 Turn off printing service
6 Turn on auto optimise from device care but inside that turn off 'close apps to free memory' (Force closing apps do more harm).
7 Go to permission manager-> location-> show system apps and select 'allow location only when app in use' for all possible apps individually
8 Go to google from setting -> on device sharing -> remove 3rd party apps except google apps
9 Again google -> device connection-> turn off nearby share, devices, cast media control, android auto
10 Turn off auto update from both play store and galaxy store. Also go to notifications of these both and turn off notifications like promotions,deals,recommendations.
11 disable these bloatwares->
(My galaxy, facebook services)
12 Put these apps in deep sleep->
(Appcloud, Galaxy themes, samsung Internet... etc)
13 Turn off background activity and data usage of these apps->
(Discover, samsung visit in, samsung push service, wallpaper service and any app that you don’t wanna run in background
14 Go to Notifications of Google and Turn off things that you don't care about like stocks, promotions, price drop alert.
15 Turn off 'ok google' detection from assistant.
01-24-2021 01:27 PM in
Galaxy Meven you close apps but they uses ur battery and running in background unnecessary, see image(1) and read the statement.
2nd due to huge notification options.
for e.g ; Google has huge notification which we don't need at all see image(2) just scroll up and down and check how many notification it does have.
So do these settings to stop, which consume battery unnecessarily.
1. Settings>>Connection>more connections settings> disable nearby device settings
2. Settings>>Location>improve accuracy >disable
A. Wifi scanning
B. Bluetooth scanning .
01-24-2021 03:56 PM in
01-24-2021 09:18 AM (Last edited 01-24-2021 09:19 AM ) in
01-24-2021 11:25 AM in
A. Wifi scanning
Galaxy M3. Device care>battery >power mode>select "optimised" and "adaptive power saving".
And enable these 2 options.
A. Adaptive battery
B. Put Unused Apps to Sleep.
4. Long press on each app specially 3rd party(LIKE FACEBOOK, YOUTUBE) and rarely used apps and also ON "GOOGLE APP" as well, then click on>app info> then go to these 3 options below on by one
5. Go to settings> privacy > permission manager > location> and check which app have accessing your location all the time and if not using that apps then deny access or set as " allowed only while in use"
6. Go to settings > Google > on device sharing> check which 3rd party apps present there for e.g. if you use paytm , paytm will shared data to show recommendation and suggestion which also cause battery drain
7. Go to settings > account and backup> account > checkwhich app syncing automatically there and if any app which not necessary to auto sync then click on it and disable sync.
8. Go to settings >apps>search "weather" >click on settings icon right side > change "auto refresh" settings as per your requirements and disable some unnecessary reminder. ( due to auto refresh it continuously consuming battery)
10. Settings>>Google >click on 3dot at right top corner>usage and diagnostics >off this option.
01-24-2021 04:01 PM in
01-24-2021 04:10 PM in
Galaxy M
