2 weeks ago (Last edited 2 weeks ago ) in
Galaxy M
2 weeks ago in
Galaxy MDear Samsung member,
Please perform the below-mentioned troubleshooting steps, these may help in resolving your concerns.
▶ Galaxy device Battery drainage issue: Note: Charge in one go instead of charging many times as it affects the life span of battery and battery performance.
4. Adjust screen timeout settings: Go to Settings > Display > Screen timeout > Select the minimum screen timeout.
5. Check which application is or interface is using more battery from device care and try to update app or avoid using that app.
6. Turn off auto sync of e-mails, app data etc.
▶ Galaxy device heating issue: 1.Turn off Wi-Fi, GPS, Bluetooth, and other connectivity features when not using them.
2. Decrease the screen brightness.
3. Close background running apps.
4. Uninstall the unnecessary apps.
5. Reduce long duration of graphics intensive gaming sessions as it may cause heating issue.
6. Avoid usage of mobile phone when charging.
7. Update software: Go to Settings > Software update > Download and install > Check for software update > If Software update available > Download > Downloading updates > Install now
8. Reset the device:
IMPORTANT:
• For this:
Please follow the below steps to reset the device: Settings > General Management > Reset > Temporary cloud backup or External storage backup > tap on Factory data reset (This will erase all data, including files and downloaded apps)
If the issue still persists, after performing all troubleshooting steps, would request you to please visit the service center. Below is the link to find nearest service center
http://www.samsung.com/in/support/servicelocation/
2 weeks ago in
Galaxy M- Mark as New
2 weeks ago in
Galaxy M
a week ago in
Galaxy MSo i tried resetting the phone as well. Nothing has changed.
I feel like this happened after i update the aprils Google Play Services but can't say for sure.
I even went to the Samsung service centre to ask why the issue is persisting even after I have gotten the battery changed. They said that it is a mother board issue now. I am thinking of getting the m56 now. Can't waste my time in this phone.
a week ago in
Galaxy MAfter factory reset problem isn't solve. Google play services is charged 5-10 % in 100% battery usage.
a week ago in
Galaxy MI've been having the same problem for the past week or so. Google Services drains my battery overnight if I left the charge at 50% or less.
Tuesday in
Galaxy M
