Battery issue
(Topic created on: 05-15-2021 12:30 PM)
Sajid48088
Tech Talk
After updating android 11 in my samsung galaxy m51 device, battery performance has been decreased. It is draining it's battery performance so fast. Give me the solution of this problem plz
kosika
Tech Talk
No. From the day of purchase - Nov 2020
Sajid48088
Tech Talk
I am facing this problem since march when i updated this android 11.
But after that, i got just security related update. When this battery draining bug fixed update will come? Any idea?
Edwin7878
Tech Talk
Did you install the April security patch
Sajid48088
Tech Talk
I install the security patch on 10th may
Edwin7878
Tech Talk
I was too facing many prblms after Android 11 update
But after the April security patch
Everything was improved in my m51
Tech Talk
If it got solved again it happened it may be a problem of your battery though
Tech Talk
Was it solved after security update???
Sajid48088
Tech Talk
No. Still facing this problem
Tech Talk
Disable always on Disable and auto scan option.
Sajid48088
Tech Talk
Didn't understand this. Make it clear plz
